the never ending build
  • mentaleeill
    • 850
    figured its time for a build thread. although i dont have any before pics of the car,as they got lost on a crashed comp., an 88 stock super eta is pretty easy to picture.
    i bought the car to use as a cheap daily, well that got old fast. i swapped in an is intake manifold, throttle body and dme, lowered it, and put on some cheap 17" wheels. that lasted a good 2 weeks until i swapped the auto out for a getrag 5 speed, another month goes by and i decided i needed a dohc engine, so out came the m20 and in went a 92 non vanos 2.5.
    that kept me happy for a little while so i figured i would concentrate on making it look better. i dropped the car off at my brothers shop for some paint and body work. he pulled and rolled all 4 fenders, shaved the antenna, keylock, and windshield squirter holes. the car was then blocked and sprayed with mocha schwartz (mercedes) paint and reassembled. i always hated the factory e30 side moldings, so i had my brother make me a custom e36 m3 like set. while the car was at my brothers i had acquired quite a few more parts, kw variant 2 coilovers, all new movable suspension pieces, all poly bushings, and a set of brock b1 16x9 wheels with 215/40 tires. all together i was pretty happy with the car at this point.
    over the next year i drove the car making subtle upgrades, chip, exhaust, german interior pieces, and just tightening the car up. i had a good, solid, daily drivable car, that handled great, was semi quick, and looked really good. well my friend nick went to germany and found this beautiful euro cloth plaid set of seats, so i had to have those, and in they went.
    fast forward a couple months and it gets colder, i get bored and out comes the motor. time for a 2.8 liter 84mm crank and an engine rebuild. i reinstalled the newly refreshed and stroked engine with a uuc cerametallic clutch and zf 5 speed trans from a 96 328. a little faster, i still wasnt satisfied.
    this is when the bug really got me. i bought a vortech v1 off of a buddy of mine, and accumulated all the parts necassery to supercharge my car. i fabbed all the brackets and wired the perfect power smt6 in. upon mounting the supercharger i had already decided i wanted more. never even turning the car over i yanked the charger and brackets out, and sourced all turbo goodies.
    i built my manifold using jays flange and donovans collector. installed a master power super t70 turbo, 18x12x3 fmic and a full 3" exhaust, but i never got it to run right with the piggy back. so out that came and in went a megasquirt 2v3 assemled by me. the plan was to run 10lbs, but of course that got scrapped and i installed a .140 mls and arp studs to lower the compression, and on to 18lbs i went
    . well i kept inching my way higher and higher just to see where i could get. at about 22lbs the gasket finally quit, hydrolocked, snapped a rod, and it took out the entire bottom end.
    which leads me here:
    cp forged pistons 85mm bore 8.5-1 comp. with coated tops
    eagle 135mm forged h beam rods
    84mm m52 crank
    mls .070 gasket a new arp 200 non undercut studs
    the head was previously refreshed and received a 4 angle valve grind
    here we are loaded up going to the machinist for bore and entire rotating assembly balance.
    somewhere in here i swtched to bbs rms 15x8.5 and 15x 6.5. but now i am on 16x9 schmidt modernlines with 225/40 tires.hopefully i will have everything back from the machine shop later this week and i will update this thread accordingly.
  • Miasma
    • Apr 2007
    • 2009
    Cool build.
    • Eric Giles
      • 1068
      Impressive-very impressive. Looks like your brother did a very nice job on the bodywork and paint, and I like how the modified body moldings look. Excuse my ignorance, but I can't figure out exactly what the aluminum 'blowneuros' thing is for...
      Also, which replica M Tech 2 rear valence are you using?
      Eric Giles
      '20 M2 CS
      '04 M3
      '11 X5 35D
      '87 325is
      '91 325i Sport
      There are few things more expensive than a cheap BMW...
      • E30SPDFRK
        • 5716
        Awesome, I've always wanted to see a build thread on this car.
        Do you still have the V1?
        Byron
        Leichtbau
        • guibo09
          • Dec 2008
          • 834
          is that a 24" or 22" mono wiper? can you make it sit any lower?
          90 E30 325i
          • abepark
            • Feb 2006
            • 384
            yes I am ignorant and want to know what that alum part is as stated before? just decoration? nice looking paper weight, or a cupholder.
            • craz azn
              • 752
              Looks like a Torque plate to me.
              Love the bodywork on this car, paint is flawless in pictures/shoots. Did quite a number on that motor though, woowweeee never seen internals that badly mashed.
              Rippin' Proper | Youtube | Vimeo |
              • mentaleeill
                • 850
                aluminum thing is a torque plate. its get bolted to strees the block as if the head were on it when it gets bored and honed. im sure the new arps at 130 ft lbs are gonna twist it a little bit and this will make the cylinders straight when torqued rather than being pulled and misformed.
                • mentaleeill
                  • 850
                  its a 24" wiper. i can park it wherever i want, but like it where it is.
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    sub-fucking-scribed
                    • dude8383
                      • Jan 2005
                      • 10387
                      hey quick question, what are you doing about cooling?
                      more specifically what fan are you using to keep that monster cool?
                      insane build and i must admit that you have been infected with the turbo virus badly!
                      • So Live
                        • 2512
                        What are you using for heat shield on the plastic engine cover thing?
                        You know how i feel about your car :)
                        -Chris
                        • jrossowvue30
                          • Nov 2007
                          • 328
                          Any interior shots?
                          2004 BMW e60 525i - Daily
                          1996 BMW e36 M3 - Toy
                          1994 Jeep Wrangler - Summer Toy
                          1993 Range Rover Classic - Handsome Looker that never gets driven
                          • e30esque
                            • Jan 2008
                            • 505
                            Nuts man. Hows coke biz? Must be doin well to afford all that.
                            (jk but seriously, wtf. what do you do?)
                            • mentaleeill
                              • 850
                              cooling is handled via a 16" spal pusher fan, m42 radiator, and 88* thermostat. on the hottest(100*) of days i cruise at the 1/4 mark and i can be in traffic and never go above 1/2.
                              i used some heat tape that i got from the local performance shop on the plastic cover and it holds up well.
                              and no drug sales here, im a foreman for a large scale commercial construction company. i actually just finishing remodeling bumblebeemers(saw his car atleast 3 times there) favorite bk in Brick.
